AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Rendering Plant 3D Components in Standard AutoCAD
3 REPLIES 3
2004 Views, 3 Replies
We have created ortho drawings in Plant 3D with a manually created viewport that references an iso view of our model rendered as SHADED. It displays and plots fine. However, when we bring this same ortho drawing up in standard AutoCAD (2011) some of the components in the rendered iso view display as wire frame and will not display as SHADED like the rest of the components.
Why is this and how can we get AutoCAD to render all Plant 3D components as SHADED?
3 REPLIES 3
TomislavGolubovic
Does the machine with the AutoCAD have the Object Enablers installed? If you don't want to use the live model, do a EXPORTTOAUTOCAD on the original model, save it as another one and then use that?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
in reply to: TomislavGolubovic
Hi Tomislav.
I'm not sure if Object Enablers is installed on my machine. How do I find out?
Could you reply to my same post at davetyner under AutoCAD Plant 3D? PlantSalad there is also commenting on this and I'd like to get both of your comments.
Thanx.
TomislavGolubovic
Download the Object Enablers for Plant here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=17658426&linkID=9240618
If that doesn't fix it, then I'm not sure. Like I said, doing the export means you have two copies of the model, a live Plant3D version, and a DWG snapshot at the time of the export.
Try the Object Enablers first, see how you go with that.
Tomislav Golubovic
”Boost
