AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Remove OPERATOR text on ISO
2 REPLIES 2
snijdam
1490 Views, 2 Replies
Is it possible to remove the "OPERATOR UP" text place on the ISO?
Stephan
Tags (3)
2 REPLIES 2
Venkatesan.A
in reply to: snijdam
Make sure your "Enabled" Value is set to "false" in the below two lines of your Isoconfig.xml for the respective iso style.
<ComponentScheme Name="ValveOperator_Skewed" AnnotationStyle="Standard" Format="OPERATOR {0}" Grouping="false" Enabled="false" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="ValveOperatorSkewed" Fields="DIRECTION" />
<ComponentScheme Name="ValveOperator_Primary" AnnotationStyle="Standard" Format="OPERATOR {0}" Enabled="false" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="ValveOperatorPrimary" Fields="DIRECTION" />
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
Autodesk, Inc.
jer.luka
in reply to: Venkatesan.A
I have a similar question: how to remove ISO text operator from a certain valve or two? The rest I would like to  keep as they are.
I have removed operator parameter from block and also I have no ValveToSpindleSkeyMap connection yet it's still showing up operator.
What to do?
”Boost
