AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Remove OPERATOR text on ISO
2 REPLIES 2
1517 Views, 2 Replies
Is it possible to remove the "OPERATOR UP" text place on the ISO?
Stephan
Tags (3)
2 REPLIES 2
Venkatesan.A
Make sure your "Enabled" Value is set to "false" in the below two lines of your Isoconfig.xml for the respective iso style.
<ComponentScheme Name="ValveOperator_Skewed" AnnotationStyle="Standard" Format="OPERATOR {0}" Grouping="false" Enabled="false" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="ValveOperatorSkewed" Fields="DIRECTION" />
<ComponentScheme Name="ValveOperator_Primary" AnnotationStyle="Standard" Format="OPERATOR {0}" Enabled="false" Grouping="true" Alignment="FlatHorizontal" LeaderStyle="AsNeeded" Filter="ValveOperatorPrimary" Fields="DIRECTION" />
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Venkatesan.A
Support Specialist
Product Support
in reply to: Venkatesan.A
I have a similar question: how to remove ISO text operator from a certain valve or two? The rest I would like to  keep as they are.
I have removed operator parameter from block and also I have no ValveToSpindleSkeyMap connection yet it's still showing up operator.
What to do?
”Boost
