AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Remove nominal size remarks on ISO
7 REPLIES 7
Message 1 of 8
Attila.Vallyon
1015 Views, 7 Replies
Hi !
How can I remove all nominal size remarks on the ISO of all components?
Thanks in advance!
Attila Vallyon
7 REPLIES 7
Message 2 of 8
Do you mean on the Iso itself, or in the BOM?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
Message 3 of 8
On the ISO drawing beside the items.
Attila Vallyon
Message 4 of 8
I've run a line on some of my Iso Styles and they don't show. Have you modified the Iso Style in any way?
Tomislav Golubovic
Message 5 of 8
I use P3D 2012 SP1.
Yes, I changed couple things, but I did not touch those kind of variables in the isoconfig.xml.
Attila Vallyon
Message 6 of 8
Was a solution ever found for this?  I have the same issue and have been looking on the forums trying to resolve it.  I have looked in the .xml files as well but can find nothing to change this. Thank you.
Message 7 of 8
eskisa0100
in reply to: Attila.Vallyon
Seeing as this post was over 2 years ago, I'm sure you've already figured this out, but...
I was having this problem also so I went into the isoconfig.xml for each ISO titleblock and removed the NS here:
Annotation Schemes / Property Change Scheme-Size (size is in green if you use foxe) / format - {0} NS (backspace 3 times to remove the space after the 0 as well)
I ran an ISO and the NS was gone!!!
Good luck!
Message 8 of 8
Gert_Strydom
in reply to: eskisa0100
Thank you for the entry, this was a massive help.
”Boost
