AutoCAD Plant 3D Forum
Remove Coords from Isometrics
8 REPLIES 8
Message 1 of 9
thebearjed
4300 Views, 8 Replies
i saw this post..http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Removing-Elevation-from-Isometrics/td-p/3286019...and was wondering if there is a similar way to turn off the coordinates on the isos?
fyi, i unchecked the Append Coords box in project manager.
8 REPLIES 8
Message 2 of 9
In the project configuration, that tickbox for appending co-ordinates is for each type of End Connection Annotation. Make sure you scroll through each option and deselect the co-ord option.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Message 3 of 9
in reply to: TomislavGolubovic
cant seem to find out how to turn off the x and y co-ords but leave the z co-ord
for 'cont'd on', 'cont'd from', 'connected to' ...etc annotations
ie I just want:
CONT'D ON:
EL + 879
not:
E 896876
N 789769
EL + 879
Message 4 of 9
TomislavGolubovic
in 2012 or 2013 rich?
Tomislav Golubovic
Autodesk, Inc.
Message 5 of 9
doh..didnt i say...oops
2012
Message 6 of 9
jhamilton
Did this question get answered.  I have the same situation and really need the fix.
Message 7 of 9
in reply to: jhamilton
i havent been using plant for a while, no plant3d jobs in australia apparently (unless youve spent 20 years in an oil and gas job regardless of competence...dont get me started...lol)
this was a core function the way the code was written, its not possible to toggle them individually, they are parsed as a single field entity with Easting Northing and RL
i doubt if this has been changed, I chased this for a while back in 2011/2012 but got nowhere
Message 8 of 9
TomislavGolubovic
This is an answer I got about this
Try this, turn off/uncheck the Append Coordinates and Elevation box under project setup for each End Connection Annotation type and open the Isoconfig.xml, search for “ElevationScheme – Elevation” or “ElevationScheme – ElevationExtended” and set the Enable value to “true”, use either 1 or 2 depending on how you want your elevation to be displayed.
Tomislav Golubovic
Autodesk, Inc.
Message 9 of 9
Hi Rich
I have same problem as yours and I am just intersted inelevation not X & Y. wondering did you able to find the way to remove x & y values?
Regards, Saman
