Hi there:
we have a model to cut out 2D plan view.
the pipe center elevation is always from ground floor which is not convenient for site crew.
how to set the elevation to from current floor, say 2nd floor @ 167" FF.
Are you working in Plant 3D 2014? If so, then when you create your ortho and choose to annotation Center of Pipe [COP
]. It is placing the elevation in reference to the Plant 3D model. The COP is taken from the database information that is also used with generating Iso's. So, this value cannot be changed. You would have to manually change the elevation if you wanted to value to be different.
Quentin Contreras
Technical Support Specialist
