Help Please? I am trying to code some refrigeration stop valves, as per the images attached. They are through valves, but the body is angled. They can have either a seal cap or a handwheel. If anyone has some advice on the best style to use for the spec editor & the best way to cater for the 2 operator types, I would very much appreciate the experienced head start. Many thanks,
Are you using Autocad Based blocks to create your Plant 3d Model for the catalog or are you trying to use the shapes Plant 3d provides? We have created some of the same valves however we used Autocad based blocks and have found success in creating and utilizing the exact same valves.
Two ways, create a autocad 3D model of the valve, then add it to the catalog as custom component, or create just the operator 3d model then add it into the catalog? This might work for you hopefully. Thanks and God bless.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
I was trying to keep it simple by using the standard valve in-built symbology. I have added the valves (based on a globe valve style) & am adding the operator but I am unsure how to add the operator at the 45deg angle & whether I can use both a seal cap & handwheel, as per the options.
I was looking in to AutoCAD 3D objects but I was unsure whether the isometric representations would be ok? Do you have any experience on these valves & what you found worked best for the specs, the users & the output to isometrics?
I appreciate the questions you posed; thank you
I had been creating custom specs and catalogs for a while now for Company and other business as well. Normally i use custom symbols as well, but allfalls down and depends on your requirement on Isometric output.
Best Regards,
Pat Andres
GHD Manila
