I have problems in the report creator eat these items on the issue of nominal diameter, can someone help me solve
following image below:
We have the same problem. Here is a not so quick fix. In the catalog you are pulling your specs from you set the Long Description Size to both sizes. For example you you have a 4"x2" Concentric Reducer type in 4"x2" in Long Description Size of the component. This worked for us.
What we do not understand is that both sizes come out on the isometric BOM without having to do the above change. It woud be nice if we could have the size read from the size column in the catalog for our reports.
Hope this helps.
mickey
