AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Reducer definition in Catalog Builder
9 REPLIES 9
Message 1 of 10
samsonthomas7606
1273 Views, 9 Replies
Hello Friends
Anybody tried creating catalog with  concentric or eccentric reducer?
Currently when I create catalog with reducer, there is only option of 1 size reduction. Is there any other better way to define reducers?
When I try to use this fitting in model the size show up as 2" instead of 2"x1-1/2"
Same thing apply to reducing tees.
Thanks in advance
Samson Thomas
9 REPLIES 9
Message 2 of 10
Have you had a chance to look at the AutoCAD Plant 3D Catalog Builder Hands-On Lab? There is a section that steps you through creating a Concentric Reducer. Please refer to this and there might be something in the steps you did not include.
http://aucache.autodesk.com/au2011/sessions/4214/lab_handouts/v2_PD4214-L_Radhakrishnan.pdf
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Quentin Contreras
Technical Support Specialist
Message 3 of 10
Hello Quentin,
Thanks for the pointer. I am able to make the concentric reducer.
Samson Thomas
Message 4 of 10
Do you have a link to more handouts similar to this one?
Message 5 of 10
Be sure and check out the Whitepaper section of Plant Exchange.
http://autocad.autodesk.com/?nd=whitepapers
Quentin Contreras
Message 6 of 10
Yes I do have access to Autodesk University
Message 7 of 10
Creating Eccentric reducer catalog, I am getting Error- Invalid class name when I tried to import excel file to make catalog. Any reason for this error?
Samson Thomas
Message 8 of 10
I figured it out. I was not filling the last columns of the excel spreadsheet properly.
Message 9 of 10
Dear sir,
Can you help me on this error, basically i am trying to create a new component using script.
I generated py file and compiled and generated pyc file. and pasted in custom script folder.
and through catalog builder when i select this script file message as below.
Kindly help please
regards
Message 10 of 10
in reply to: quentin.contreras
Hi Quentin,
I've looked at the reference of the AutoCAD Plant 3D Catalog Builder Hands-On Lab.
However, what do we do with the SizeRecordID_S1 and SizeRecordID_S2 values. I am using Plant 3D 2018 and when I export to Excel these two columns are filled in, unlike the Hands-on lab where no value is assigned.
Your assistance in this regard would be much appreciated.
”Boost
