AutoCAD Plant 3D General DIscussion
New Member
erenst
Message 1 of 2 (265 Views)
Rectangular ducting
265 Views, 1 Replies
02-03-2013 07:30 PM
Hi
I use 3D plant for Coal Processing Plant detail design, most of the equipment use chute and rectangular ducting as solid transfer, how to set up rectangular duct in 3D plant.
best regard
Active Contributor
rchiasson
Message 2 of 2 (249 Views)
Re: Rectangular ducting
02-04-2013 05:02 AM in reply to: erenst
Unless AD has released a new catalog, there is no option for duct work. You could create custom components, but I would imagine it would be a good bit of work. If you look at the spec editor, there are placeholder box fittings, but I didn't see any options for straight box shapes. You'd have to build it custom.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
