AutoCAD Plant 3D General DIscussion
Member
yunus.batmaz
Message 1 of 5 (691 Views)
Railing on the Tank.
691 Views, 4 Replies
09-16-2011 05:35 AM
I want to install railings on the cylindrical tank. I saw only the flat railing in the upper menu. How can I do railing on the tank?
Thanks for help...
Tank top railing
Valued Mentor
ybogdanov
Message 2 of 5 (677 Views)
Re: Railing on the Tank.
09-16-2011 01:32 PM in reply to: yunus.batmaz
In Plant is not possible to create circular railing, But you can use the AutoCAD commands to do this. Create one vertical pipe and use the polar array. After this sweep command to create top railing pipe and others...or use "donut" command to create the horizontal pipes.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Member
yunus.batmaz
Message 3 of 5 (662 Views)
09-17-2011 01:29 AM in reply to: ybogdanov
This is of course a different solution.
But this railings, in Plant3D Data Manager system will not be processed.
Thanks Mr. Bogdanov.
Valued Mentor
ybogdanov
Message 4 of 5 (660 Views)
09-17-2011 03:12 AM in reply to: yunus.batmaz
The part of structure of Plant3D is don't have presision components, because is only use for have reference in 3D. If you want to create perfect structure you need to create it in AutoCAD Structural Detailing 2012.
Yury Bogdanov
Barcelona (Spain)
Product Support
Dan.Scales
Message 5 of 5 (607 Views)
09-21-2011 07:51 AM in reply to: yunus.batmaz
Another option is to draw an AutoCAD polgon that has the same number of sides that the railings would have and then use the endpoints of the lines to place the sections of railings:
This is fairly quick and easy to do.
Dan Scales
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
