Good day:
I have 4 users work in the same project, when 1 of them want save the project, pop up message Project Currently in Use, then eraser the files
in the server:
IsoPart.xml.plck
OrthoPart.xml.plck
PipingPart.xml.plck
PnIdPart.xml.plck
and i can save.
The following actions are performed:
actualization of service packs.
procedure PURGA in the project.
Delete temporary Windows.
Delete files of folder GraphicsCache
Please help me! Thank you
I see this post:
http://blogs.rand.com/support/2013/06/plant-3d-message-project-currently-in-use.html
investigating I saw that the problem is that sqlite BD is used, it is advisable for a project in which several clients is that working was performed with the BD xpress or SQL server. And if you have a project with sqlite can migrate to one of these two BD
