AutoCAD Plant 3D Forum
"Copy Drawing to Project" error - Network Re-Mapping
3 REPLIES 3
Gabriel.N
629 Views, 3 Replies
Our server was changed and the mappings were lost. Therefore it was necessary to remove the drawings from the project and re-input them again. I tried to do that, but I keep getting the following error:
"PnPCompletionStatus.FailedToAcceptChanged
Abort due to constraint violation
PRIMARY KEY must be unique"
Check annex PrintScreen.
What can I do to solve the problem.
Thanks.
3 REPLIES 3
in reply to: Gabriel.N
I am having the same problem with the identical error in AutoCAD P&ID. It appears that this question has gone almost 2 years unanswered but because an answer is still relevant to me, here is a bump
patpat79
Hi can you attach more snap of your problem? how about the snap project manager of your project.
Best Regards,
Pat Andres
Autodesk Expert Elite
Plant 3D Administrator
GHD Manila
in reply to: patpat79
The last thing I did before I left the office yesterday was run a second project validation and it appears to have fixed the problem as I can no longer cause the error message to appear. I think that my office may have still been having network issues yesterday and that seems to have either been the cause or contributed to the problem, as the first validation I ran yesterday did not solve the problem.
”Boost
