Anyone have any idea why this would happen? If I have a component that needs connected to a nozzle and I right-click on the component and select "Connect Component To Adjacent" then pick the nozzle I want to connect it to, it inserts a pipe support and doesn't connect the comonent to the nozzle. I have no idea how the two are even related so I can't figure out why it's doing this.
I get this quite often as well, but not everytime. For me, it seems to only happen when one of the models is xref'd. If I reload the xref, it seems to update the image.
I would like to know the reason as well. I'm on 2014 ext2.
With the valve you are connecting to the nozzle. Is there a reason why the valve should not connect anyways when you place them together using node placement?
I am not sure about the support being placed though. Is this something that you can easily recreate?
If I am missing something let me know.
Quentin Contreras
Technical Support Specialist
If I disconnect the gasket and blind flange on the other side I can get it to connect using node plecement, and that's what I ended up doing. Sometimes things just disconnect though and it's easier to just right-click, Connect To Adjacent. This happens on other peoples machines too.
This is something that seems to randomly happen on certain connections. I don't know where else this is occuring but I'm sure I could track one down if I had to.
