regards
Syed
Solved by OmarGT. Go to Solution.
Try on isometric dwg settings and setup title block; there you can change what you want. As it is showed, in the attachment, in th Iso Theme you can change the text, the sort of default styles. See that the content of the cell that its text appears in cyan color is locked; you can unlock it, modify its color, and then lock it again. There is a different way of changing it; but it is more complex, it is changing the xml file.
Thanks Omar,
took your guidance and it helped.
I’m still trying to find out how to either change the format for or get rid of the isometric line number annotation (see attached, the annotation I am referring to is circled in yellow).
Let me know
regards
Syed
Edit the Isoconfig.xml file and look for the following line:
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{0}-{1}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
And change it as follows:
<LineNumberScheme Name="LineNumber" AnnotationStyle="Standard" Format="{}" Alignment="SkewAligned" LeaderStyle="AsNeeded" ComponentFields="Size PIPING-SPEC" LineFields="PIPELINE-REFERENCE" ComponentFormat="{0}-{1}" LineFormat="{0}" />
