AutoCAD Plant 3D General DIscussion
Active Contributor
dogyeom
Message 1 of 1 (171 Views)
[Question] Pipe,Nozzle,Flange
171 Views, 0 Replies
12-12-2012 07:03 PM
I have 1 question. (about AutoCAD Plant 3D)
This is the sequence I've been working.
1. I Open tutorial project. (Project Name : Modify and Reuse Data)
   (This sample file as well as in other projects, this situation occurs.)
2. And Open Piping drawing file.
3. Next, Delete pipe and flange.
4. Again, Route pipe, from the nozzle.
In this case, flange does not generate.
I found one workaround.
However, this method is very inefficient.
This is what I figured out.
1. I Open Equipment drawing file.
2. Select the nozzle. (Nozzle flange does not generate.)
    These nozzles when you click the + (Continue pipe routing) does not mark.
3. In order to solve this problem, Click the Edit nozzle(Pencil icon).
4. And change the value of Change Location.
5. Next, Save Drawing.
6. Come back pipe drawing.
7. Again, Route pipe, from the nozzle.
When set in this manner, + (Continue pipe routing) Mark reappears.
And When the piping work, go back into the drawing.
Flange is generated.
Again, this is a very uncomfortable way.
In particular, in many cases the nozzle.
Why this situation occurs? (Flange does not generate.)
And Is it the best way? I want to handle at once.
Difficult sentence above?
Then Follow the links below.
http://blog.daum.net/utalpian/2236522
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
