AutoCAD Plant 3D General DIscussion
0 Kudos
Post 1 of 2
Query equipment dimension data from database.
145 Views, 1 Replies
08-20-2012 10:47 AM
Hiya! I am trying to report on equipment dimension data from the project database. Is this possible? Thanks!
0 Kudos
Post 2 of 2
Re: Query equipment dimension data from database.
08-22-2012 05:24 AM in reply to: davetyner
http://www.davetyner.com/forum/showthread.php?11503-Extracting-equipment-dimension-data
OK so after much discussion, debate, desk slamming, and paper crunching yesterday, I was able to connect with Autodesk technical ace Ken Fauver. Ken informed me that although you cannot get the equipment dimension data strait from Plant 3D, you can get it from the manually entered data on the corresponding P&ID. My issue is that I don't have any P&ID's on this job, just the model.
I would love for this to be a feature in upcoming releases of Plant 3D. If nothing else, just the bounding box info of the object would be fine. I can get some of the data I need through arx but it's a hassle. Would be nice if it was already there .
Post to the Community
New Post
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
