AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Python script for parametric elements
1 REPLY 1
ybogdanov
911 Views, 1 Reply
 Is it possible to add new parametric elements with python script?
I see that all elements stay in "variants" file in CPAK Common folder. For example, pipe have parametric code "CPP", and it's programmed that it will be cylinder. May be is posible to add new parametric form for pipe and it will be square?
 Or for example to create new form for valves or clamps.
Thank you
Regards
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
1 REPLY 1
Venkatesan.A
in reply to: ybogdanov
Yes you could do that.
Dave Is conducting a class during this year's AU on this topic.
https://www.autodeskuniversity2012.com/connect/sessionDetail.ww?SESSION_ID=1746&tclass=popup
Venkatesan.A
Support Specialist
Product Support
”Boost
