AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PVC Flush bushing issues with ISOMETRICS solved
2 REPLIES 2
JohnHolder
641 Views, 2 Replies
Finally figured out how to deal with flush bushings for SCH 40 PVC, and how they work with ISOMETRIC drawings.
I modeled up to spec flush bushings - in the spec editor I was using custom blocks. the issue was that they broke ISO drawings since there is a "negative" pipe length. eg. 4" x 2" flush bushing there is a 4" PPL then a 2" PSW the 2" starts inside the 4" PPL this is what broke the ISO So going back to parametric modeling
eg 4" to 2" flush bushing
D1 4.5
D2 0
L 0.469
OF -1
L1 -2 ( This should be 1.031if it is modeled )
L2 1.875
I2 1.875
When I finally realized I had to make L1 = -2 it worked. I still cannot place a flush bushing inside a flush bushing, but I just modify the description to state there are two fittings to get the desired reduction. I am trying to get away from custom blocks since the sch 40 catalog is missing a vast majority of the parts I use. This was preventing me from using ISO drawings. now I have to figure them out.
Yes I am a little excited.
*edited for formatting since this forum hates anything but internet explorer*
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
2 REPLIES 2
ahepker
in reply to: JohnHolder
Hello John,
If possible, would you be willing to post a couple example PCFs that contain the bushings that you're referring to? Every time I try to create an iso with a bushing anywhere between 2 other objects, I get an error. I've tried almost every type of end connection and Skey that I can think of, including customs, to no great success.
I've included the error log and the pcf below. Any input you might have would be greatly appreciated.
Iso Creation start time : 4/30/2016 8:20:18 PM
Iso Creation finish time: 4/30/2016 8:20:20 PM
Duration : 00:00:02
Output folder : C:\CADD\10-P3D Project\Isometric\KSI_ANSI-B\ProdIsos\Drawings
1 Isometric(s) were not able to be created:
C:\Users\andrew.hepker\Desktop\L0-0170-ISO-PCW-09a.pcf
INFO - Loading input: 'C:\Users\andrew.hepker\Desktop\L0-0170-ISO-PCW-09a.pcf'
INFO - Loaded '1' model(s).
INFO - Processing: 'L0-0170-ISO-PCW-09a'.
FAILURE - eInvalidExtents
ISOGEN-FILES ISOGEN.FLS
UNITS-BORE INCH
UNITS-CO-ORDS INCH
UNITS-BOLT-LENGTH INCH
UNITS-BOLT-DIA INCH
UNITS-WEIGHT LBS
UNITS-WEIGHT-LENGTH FEET
PIPELINE-REFERENCE L0-0170-ISO-PCW-09a
    REVISION  0
    PROJECT-IDENTIFIER  projectnamevalue
    AREA  areanamevalue
    FLOOR  floorvalue
    DRAWINGNAME L0-0170-ISO-PCW-09a
    ITEM-ATTRIBUTE1  projectnamevalue
    PIPING-SPEC  CPVC Sch 80
    DATE-MDY  04/30/2016
COUPLING
    END-POINT  2889.4708  753.4651  116.0598  1.2500  J
    END-POINT  2889.4708  753.1951  116.0598  1.0000  C
    SKEY  CO??
    ITEM-CODE  8
    ITEM-DESCRIPTION  BUSHING, CPVC SCH 80, ASTM F439, PExS
    FABRICATION-ITEM
    WEIGHT  0.1413
END-CONNECTION-PIPELINE
    CO-ORDS  2889.4708  753.1951  116.0598
    PIPELINE-REFERENCE  L0-0170-ISO-PCW-08
PIPE
    END-POINT  2889.4708  753.1951  116.0598  1.0000  J
    END-POINT  2889.4708  606.4884  116.0598  1.0000  J
    ITEM-CODE  3
    ITEM-DESCRIPTION  PIPE, CPVC SCH 80, ASTM F441
    FABRICATION-ITEM
    WEIGHT  9.9454
    CO-ORDS  2889.4708  755.5551  116.0598
    PIPELINE-REFERENCE  L0-0170-ISO-PCW-02
PIPE
    END-POINT  2889.4708  755.5551  116.0598  1.0000  J
    END-POINT  2889.4708  770.2625  116.0598  1.0000  J
    ITEM-CODE  685
    FABRICATION-ITEM
    WEIGHT  0.9970
COUPLING
    END-POINT  2889.4708  755.2851  116.0598  1.2500  J
    END-POINT  2889.4708  755.5551  116.0598  1.0000  C
    SKEY  RC??
    ITEM-CODE  1
    FABRICATION-ITEM
    WEIGHT  0.1413
    CO-ORDS  2889.4708  753.4651  116.0598
TEE
    END-POINT  2889.4708  753.4651  116.0598  1.2500  C
    END-POINT  2889.4708  755.2851  116.0598  1.2500  C
    CENTRE-POINT  2889.4700  754.3800  116.0600
    BRANCH1-POINT  2889.4708  754.3751  115.1498  1.2500  C
    SKEY  TE??
    ITEM-CODE  6
    ITEM-DESCRIPTION  TEE, EQUAL, CPVC SCH 80, ASTM F439, SxSxS
    FABRICATION-ITEM
    WEIGHT  1.0404
JohnHolder
in reply to: ahepker
I honestly havn't done anything with isometric drawingssince that post.  I gave up trying to get them to work.  luckly they are not important to what we do.
simple piping for aquaculture projects.
Master Yoda.
”Boost
