AutoCAD Plant 3D Forum
Welcome to Autodeskā€™s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Showing results forĀ
Did you mean:Ā
Purge list of projects in Project Manager
6 REPLIES 6
ybogdanov
1360 Views, 6 Replies
How is posible edit the list of last opened projects in Project Manager? I have any 20 projects, and I want to delete any one.
Thank you
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
6 REPLIES 6
lyowbeen
in reply to: ybogdanov
I have a tools which can do that.
ybogdanov
in reply to: lyowbeen
Seems like grate tools, but there are this solution in english? This tools is modificate any file of Plant3D where is all reciento projects. It's intresting to know which file is... To modificate it manually.
Yury Bogdanov
Barcelona (Spain)
lyowbeen
OK. Give me some time, please. I'll try to translate that to English.
lyowbeen
1. Open the folder "C:\Users\DOCUMENTEN\AppData\Roaming\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\Support\Profiles\Unnamed Profileā€œ, you can find a file named "Profile.aws".
2. Open the file by notepad, and search for "MRUList". Delete the MRUn(n=1,2,3...) item. Make sure the n value continual.
ybogdanov
Thank you very much for solution!
Another question, how do you find this?? There are any document which describe functionality of program?
Yury Bogdanov
Barcelona (Spain)
lyowbeen
In fact, there is no document to describe that. We are the only partner with autodesk in China. We have lots of engineers to solve all kinds of problems from the customs who use plant 3D. This is only one of our solution lists.
ā€Boost
