AutoCAD Plant 3D General DIscussion
Valued Mentor
ybogdanov
Message 1 of 7 (453 Views)
Purge list of projects in Project Manager
453 Views, 6 Replies
07-19-2012 11:55 PM
How is posible edit the list of last opened projects in Project Manager? I have any 20 projects, and I want to delete any one.
Thank you
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
1. Open the folder "C:\Users\DOCUMENTEN\AppData\Roaming\Autodesk\AutoCAD Plant 3D 2013 - English\R19.0\enu\Support\Profiles\Unnamed Profile“, you can find a file named "Profile.aws".
2. Open the file by notepad, and search for "MRUList". Delete the MRUn(n=1,2,3...) item. Make sure the n value continual.
Active Contributor
lyowbeen
Message 2 of 7 (450 Views)
Re: Purge list of projects in Project Manager
07-20-2012 01:06 AM in reply to: ybogdanov
I have a tools which can do that.
Valued Mentor
ybogdanov
Message 3 of 7 (446 Views)
07-20-2012 02:45 AM in reply to: lyowbeen
Seems like grate tools, but there are this solution in english? This tools is modificate any file of Plant3D where is all reciento projects. It's intresting to know which file is... To modificate it manually.
Yury Bogdanov
Barcelona (Spain)
Active Contributor
lyowbeen
Message 4 of 7 (444 Views)
07-20-2012 02:54 AM in reply to: ybogdanov
OK. Give me some time, please. I'll try to translate that to English.
Active Contributor
lyowbeen
Message 5 of 7 (428 Views)
07-22-2012 07:59 PM in reply to: ybogdanov
Valued Mentor
ybogdanov
Message 6 of 7 (415 Views)
07-23-2012 10:41 AM in reply to: lyowbeen
Thank you very much for solution!
Another question, how do you find this?? There are any document which describe functionality of program?
Yury Bogdanov
Barcelona (Spain)
Active Contributor
lyowbeen
Message 7 of 7 (407 Views)
07-23-2012 06:27 PM in reply to: ybogdanov
In fact, there is no document to describe that. We are the only partner with autodesk in China. We have lots of engineers to solve all kinds of problems from the customs who use plant 3D. This is only one of our solution lists.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
