AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Purge catalog reference from Spec
4 REPLIES 4
dennis
728 Views, 4 Replies
Is there a way to purge a catalog reference from a spec?
4 REPLIES 4
TomislavGolubovic
in reply to: dennis
For what reason?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
dennis
in reply to: TomislavGolubovic
I don't know why the reason should matter?  In this case, the catalog name changed, in the effort to create standardized naming conventions.  Does that make a difference on whether I can purge a catalog reference or not?
JarrodMudford
in reply to: dennis
This will only work on specs that you have created.
You can use WinRAR to open the pspx file. Inside you'll find a folder called "editor".
In the editor folder, there is an .xml file, "CatalogReferences.xml"
This xml file contains the path for the Catalogs that are associated with the spec. You can change the Catalog name in the xml file.
Make sure you open the xml file from the WinRAR aaplication and when saving, it saves back to the archive.
Hope this helps.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
dennis
in reply to: JarrodMudford
Thank-you Jarrod Mudford, for your help.
”Boost
