AutoCAD Plant 3D General DIscussion
Valued Mentor
dennis
Message 1 of 5 (277 Views)
Purge catalog reference from Spec
277 Views, 4 Replies
02-01-2013 09:46 AM
Is there a way to purge a catalog reference from a spec?
This will only work on specs that you have created.
You can use WinRAR to open the pspx file. Inside you'll find a folder called "editor".
In the editor folder, there is an .xml file, "CatalogReferences.xml"
This xml file contains the path for the Catalogs that are associated with the spec. You can change the Catalog name in the xml file.
Make sure you open the xml file from the WinRAR aaplication and when saving, it saves back to the archive.
Hope this helps.
Employee
TomislavGolubovic
Message 2 of 5 (249 Views)
Re: Purge catalog reference from Spec
02-03-2013 11:23 AM in reply to: dennis
For what reason?
Tomislav Golubovic
Plant Solutions Engineer
Autodesk Australia / New Zealand
Valued Mentor
dennis
Message 3 of 5 (238 Views)
02-04-2013 04:39 AM in reply to: TomislavGolubovic
I don't know why the reason should matter?  In this case, the catalog name changed, in the effort to create standardized naming conventions.  Does that make a difference on whether I can purge a catalog reference or not?
Employee
JarrodMudford
Message 4 of 5 (217 Views)
02-04-2013 05:49 PM in reply to: dennis
Hope this helps.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Valued Mentor
dennis
Message 5 of 5 (199 Views)
02-05-2013 04:50 AM in reply to: JarrodMudford
Thank-you Jarrod Mudford, for your help.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
