AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
PUP Lengths
17 REPLIES 17
Message 1 of 18
JRPalmer
1405 Views, 17 Replies
PUP Lengths
IS there a way to automatically display the PUP length of a pipe on an ISO. PUP length being the length of pipe between fittings.
I could give the pipe individual item numbers and then it would display the length in the BOM, but I would rather have the PUP length displayed on the actual drawing.
17 REPLIES 17
Message 2 of 18
PeterQuinn
in reply to: JRPalmer
Yes. There is a feature of isometrics called cut piece list that is what I think you're looking for. You can set one of the option switches to turn on the cut piece list.
Peter Quinn
Senior Product Manager
Message 3 of 18
mdn_aet
Hello
Would you please help with a procedure??? how to changed it??
Regards
Message 4 of 18
bogdanov.y
1. Open Project Setup->Plant 3D DWG Settings->Isogen Settings->Configure title block
2. Select your ISO type and enter to "Setup Title Block..."
3. In the Block Editor enter to BOM Setup (the command: _ISOGENTBBOMSETUP)
4. In the "Setup Isogen Bill of Materials" in the upper part of window activate "Use type 1 bill of materials (BOM)"
5. OK->Close Block Editor-Save
6.Enter: Project Setup->Plant3D DWG Settings->Isogen Settings->Labels
7. Select your Iso type
8. Activate "Cut piece list" and OK
Message 5 of 18
JRPalmer
in reply to: bogdanov.y
Using the cut list only but labels onto the sheet though it does not actually specify on the sheet what the individual lengths of the pipe are.
The best work around I have found for that is labelling each piece of pipe with a different Item code in the properties manager. This will then automatically display a list of different lengths of pipe in the BOM on the sheet it self.
Message 6 of 18
bogdanov.y
In Iso for view cut list you need to configure the BOM list like default (1-5 pass from list that I wrote before).
The solution is anything like this:
Message 7 of 18
JRPalmer
My problem is that I want the PUP lengths on the actual ISO drawing. See attached PDF. That was done manually. I got the lengths of pipe from giving each pipe component a seperate item code.
I already know this is incompatible with AutoCAD settings because one of there technical support personnel has already told me so.
Also using Type 1 BOM takes away my ability to customize my BOM to the way my boss wants it. Is there a way to show the the cut list without using type 1 BOM, and more importantly to customize it. I would want the length of the pipe to be uo near the top with the dsecription of the pipe.
Message 8 of 18
mdn_aet
Thanks bogdanov.y
I had a costumeized BOM list, After I use 1 bill of BOM,, now my Costumemized BOM is gone. Do You know how to recover it? or any ideer?
Regards
Message 9 of 18
bogdanov.y
in reply to: mdn_aet
@mdn_aet wrote:
Thanks bogdanov.y
Regards
Turn in block editor of your ISO type and change the default settings to settings that you had before. 4th pas in the list. But Cut pipe list only appear in the "1 bill of BOM"
Message 10 of 18
jason.drew
JR,
Are you needing to display dimensions from weld point to weld point? (see example below)
Jason Drew
Designated Support Specialist
Message 11 of 18
JRPalmer
in reply to: jason.drew
Yes that is exactly what I wanted
Message 12 of 18
ybogdanov
How you do to display correct angle of elbows? For example 25º angle, in plant in default settings the angle of 25º indicate like 155º.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
Message 13 of 18
JRPalmer
How did you get it to display the measurements from weld point to weld point.
Message 14 of 18
JRPalmer
Is this one of the new features in 2012?
I have been looking through the ISO dimensioning options I can not seem to find it if it exists.
Message 15 of 18
kylepope
I'm not sure if Jason and I have similar methods, I did it by modifying the isoconfig.xml file and adding an Anchor Point called Weld.  In truth, I just copied the Field Weld, and changed it to read Weld under the locating type dimension.  This will dimension from every weld to every weld.
KP
Kyle Pope
Process and Power Specialist
ECAD, Inc
Our Blog
www.pdoteam.com
Message 16 of 18
JRPalmer
in reply to: kylepope
I tried that and it seems to work. I replaced field with Shop.
This is what I insert underneath the string dimensions
<AnchorPoint Name="ShopWeld" Enabled="true" Filter="WeldShopItem">
                <EndPoints>
                  <EndPoint EndPointType="Center" />
                </EndPoints>
              </AnchorPoint>
It seems to work with one of my projects. The other projects when I try to create an ISO is says something about an invalid output directory. Could this be because one of them is a regular database (the one that works) and the other is a SQL Express database (the one that does not)?
Message 17 of 18
kylepope
I tested mine on a SQLLite as well, could be an issue, I'll look into it more and let you know.
You nailed the string, here's how I did mine.
<AnchorPoint Name="Weld" Enabled="true" Filter="Weld">
<EndPoints>
</EndPoints>
</AnchorPoint>
Kyle Pope
ECAD, Inc
Our Blog
www.pdoteam.com
Message 18 of 18
JRPalmer
The change in the XML script did not affect the project I was in but when I created a new project based off that project it did display the measurement pbetween welds.
”Boost
