AutoCAD Plant 3D General DIscussion
New Member
rong.li
Message 1 of 8 (392 Views)
Property lost in Plant 3D model
392 Views, 7 Replies
04-09-2012 03:12 AM
Hi
As you can see in the attached dwg file.all of the property have lost.
During creating the model ,we can see all of the property .
but when we close the model,it will be lost.
Some of the property will be back when  reopen the software or restart PC.
So anybody met it before and what will cause it happen?
Thank you so much.
Valued Mentor
ybogdanov
Message 2 of 8 (388 Views)
Re: Property lost in Plant 3D model
04-09-2012 04:54 AM in reply to: rong.li
It's hapen when is useing the command "save as..." in Plant3D. In this case, the dwg detach from database, and all objects losing properties. If you delete the drawing from project and then turn add it the objects turn recover their properties.
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
New Member
rong.li
Message 3 of 8 (378 Views)
04-09-2012 07:59 PM in reply to: ybogdanov
Thank you for your reply.
I test it:
if i save as a model,we can't see the property in the new model as it doesnot belong to any project.
but if we add the model the current project or other project,we can still see the property.
So it means when we save as a model ,the new file still contain all of the property.
So anything other could cause it happen?
Valued Contributor
19820415
Message 4 of 8 (345 Views)
04-17-2012 09:34 PM in reply to: rong.li
Any body can give me some help?
it seams that it happens in severals customers and projects.
Autodesk should pay more attention about this.
It is very important and urgent!!
Thanks.
Hope for your quick reply.
Product Support
jason.drew
Message 5 of 8 (290 Views)
04-25-2012 11:09 AM in reply to: 19820415
Are you using the default SQLite database configuration for your projects, or are you running Microsoft SQL Server Express?
Jason Drew
Premium Support Specialist
Product Support
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Valued Contributor
19820415
Message 6 of 8 (277 Views)
04-26-2012 08:23 PM in reply to: rong.li
SQLite
Product Support
jason.drew
Message 7 of 8 (263 Views)
05-02-2012 02:45 PM in reply to: 19820415
I have submitted this issue to the development team and they are currently looking into a fix for the problem.
Thank you,
Jason Drew
Product Support
Member
johanviro
Message 8 of 8 (168 Views)
03-08-2013 12:21 AM in reply to: jason.drew
hello ron.li, jason drew,
I've noticed the following:
when you are working in more than one drawing and switching from one to another drawing without saving, you will lose properties too,  e.g. tagnumbers of valves...
So when you are switching between drawings:
FIRST SAVE !
Johan
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
