Not sure how this happened, but we have the two 'read only' paths pointing to the Project Package and the Symbols and Styles. How can I correct these paths? I did try editing the PnIDPart.xml but that didn't fix it.
Solved by dennis. Go to Solution.
Do you know if they changed anything, like maybe renaming the project folder, before restoring the backup project? That is the only thing I can think of that might have caused this to happen.
I would think the pnidpart.xml as well and changing the paths in there. You have already done everything I would have done as well.
Is there any chance they still have the backup and can do the restore process again?
Quentin Contreras
Technical Support Specialist
