AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Project Settings in Plant 3D using Vault
3 REPLIES 3
910 Views, 3 Replies
We have just started a pilot project using vault functionality in Plant 3D.
Project setup works just fine and so does syncronizaion and check in/out for dwgs.
We have now hit a problem - when trying to change Tag Format on eg. Equipment.
Following thet needed steps - checking out the Project Settings from Vault and checking in after modifying Tag Format seems to work. But when opening Project Settings again - the changes are not there!
For information changing for example Project Description works.
The project is empty with default settings and full admin rights to Vault.
Anyone have a suggestion?
Tags (1)
3 REPLIES 3
I share the answer from Autodesk Subscription Support - which works just fine!
You should be able to workaround this issue by clicking another button in the dialog such as "Edit Block" before clicking OK and closing the project setup.
Now Vault understands that something is modified.
JarrodMudford
This issue is not Vault related. It is ONLY related to the Extension 1 version of Plant3D 2013. Even if you create a project outside of the Vault, that issue still arises.
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Jarrod Mudford
Plant Solutions Consultant
Global Services
Autodesk, Inc.
in reply to: JarrodMudford
Thanks Jarrod for your clarification!
”Boost
