Is there a way to disable the Project Properties menu from users? I know we can set read only permissions on the projSymbolStyle.dwg which can prevent the users from editing the properties. But I would like to remove the menu completely.
Solved by martinTstewart_Adsk. Go to Solution.
I’m unaware of any way to do this. This is likely more an office policy/procedure matter –for users to not go into the properties if that’s the policy there. The read-only permissions help with that. But there is a balancing act between these kind of requirements that vary from office to office and trying to hard-code such restrictions.
That said, perhaps others in the community here have a suggestion on this…
