AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Problems with Stub Flanges and Collars
2 REPLIES 2
PatrickByrne
1704 Views, 2 Replies
Stub Flanges: In the attached sample I have 2 pipes joined by stub flanges, this works well in the model until I go to produce an Isometric. The resulting Isometric is in 3 pieces and the Isometric with the stub flanges only shows 2 welds and does not list the stub flange in the material list. I would like the stub flanges and lap flanges to appear in the material list as a separate items.
The End type for the Pipe is PL PL
The End type for the stub flange is LAP PL with an SKEY FLSE
The End type for the Lap Flange is FL LAP with a SKEY FLFL
Collars: Other pipework uses collars on the end of the pipe and bends with a lap a flange behind it. Once again this models correctly but the resulting Isometric does not show any flanges where the collar and lap flange are located. End types and SKEY’s are similar to above.
Thanks for your help.
2 REPLIES 2
PatrickByrne
in reply to: PatrickByrne
Just to add, I am using Plant 3D 2012
PatrickByrne
Found the solution.
When I converted the cadWorx stub ends across it set the Iso Symbol Type as LAPJOINT-STUB-END it should have been LAPJOINT-STUBEND
”Boost
