AutoCAD Plant 3D Forum
Problems with Reducers and Reducing Tees with Isometrics
1 REPLY 1
sschmidt118
707 Views, 1 Reply
I’m using Plant 3d 2014 and whenever I try to generate an isometric it seems to be having problems with reducers and reducing tees.  I’ve been trying to find a pattern other than reducing components. I know it has something to do with the reducing components is because if I delete the reducers everything works just fine The example I have attached shows that some of the reducing tees work but others don't.
Things I’ve tried
Plantaudit
Project Audit
Purged userdatacache
Uninstalling Plant3d and reinstalling
Repairing the Installation
 Also tried Deleting the entire line and anything pertaining after I did that I would run a project audit and purge userdatacache so that there is no evidence of it ever existing.  Then I would redraw it and still get the same results.
I would really appreciate a solution as quick as possible because I have this line along with the isometrics for 20 other lines with the same issue that are due tomorrow.
Scott
1 REPLY 1
sschmidt118
in reply to: sschmidt118
Here's more attachments
”Boost
