Halo...
Now I can see, that I have very big problem, with pipe names...
I use DATA MENAGER r to generate some report...
When I start a NEW Project and route a lines, i saw that in line list I have LINE NUMBERS from sample project, and I do not now how they existing in my project...I try to delete them, but not with success...
I saw that they are not empty, have pipe components inside, they exist in DATA MENAGER., but thet do not exist in Model, and not in Drawings....
No I see that I can not use report menager as I wish..is this some type of BUG or....
Nobody....is it possible ....
But, this problem make me a lot of problems on MTO list...
The line numbers you are seeing from the Sample Proejct are more than likely coming from P&ID's that somehow got copied to your new project. If P&ID's from the Sample Project are there try deleting them. Hope this Helps
If they are really not there, try running Project Audit to remove them.
Now I can see ....The way that Autodesk choose people is the best...
Thanks....a lot of Thanks to You for this...
