I'm trying to create isos from the 3D file, and having problems with dimensions settings. I tried a lot of combination in the settings, choosing "End to end" or "String" or "Locating" and the result is quite almost the same. For example, on a line composed only by two valves and pipe I changed settings a lot of time, but Plant always produces only string dimensions on valves and pipe. Any one have suggestions?????
Solved by Bernd.Gerstenberger. Go to Solution.
Ok! I attached also last dimesions settings and the results is still that one!
Thank You!
I tried that dimensions settings, but it doesn't work yet. I keep on trying a lot of different settings combination but the result is still the same. Maybe the problem is caused by a more general setting?? Thank You again
At this point it might be best to .zip up your iso style folder along with a small drawing. Someone here may be able to analyze it quicker that way.
You are only looking at 'default' dimension style. The top right of your clip which you attached to a previous comment, if you drop down that menu and look at the dimension styles for small bore pipe, existing etc etc.
