AutoCAD Plant 3D Forum
Problems with ISO - Lined Flange don't show!
3 REPLIES 3
1563 Views, 3 Replies
Hello at all, I downloaded the catalog Resistoflex PP lined Pipes and Fittings and i've got a problem with flange (EndType LFL) representation in isometric. Lined flanges don't be showed, see attached files. I know that in Autocad plant 3d 2012, the symbol for fixed-pipe length is not a default symbol, but i know how to solve it. My main problem is how to make the isometric show the flanged fittings correctly. Someone have any idea? Thanks!
3 REPLIES 3
TomislavGolubovic
If you look at IsoSkeyAcadBlockMap.xml in the /Isometrics/ folder of your project, that has the mapping for the SKEY's to the ACAD block it will draw in Isometric.
The default shows this: <SkeyMap SKEY = "BE??" AcadBlock ="Elbow"/>
It means that anything with an SKEY starting with BE and ending in a wildcard will draw the Elbow symbol. To change this, you will need to add your own symbol in the Isometrics settings, and change the AcadBlock entry above to point to the name of your new block.
So lets say you draw an elbow with flanges on it, and called it "ElbowFlange", so the above line would need to change to look this this:
<SkeyMap SKEY = "BE??" AcadBlock ="ElbowFlange"/>
To add the new symbol, go into the project properties, and open up the Isometrics options, and in the last dialog for Isometrics (where you setup the Title Block" there is a button for Isometric Symbols. This is where you add the new Iso block symbology. Draw it as a plan flat 2D item, just look at one of the other Elbow blocks, and give it a new name with the symbology you want.
If you want screenshots, let me know.
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk, Inc.
Autodesk ANZ YouTube Channel
Firstly, thanks for your reply.
I did what you said and it worked. But I still have a little problem, the connection between the flanges (flanged elbow and pipe fixed length) displayed in the isometric is being shown in different planes, see attached file.
How can I fix it?
FourWideJK
Did you get this solved ?  Im having the same issue now with 2013
”Boost
