AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
problem with pipe socket
3 REPLIES 3
mcray100500
540 Views, 3 Replies
Hello, colleagues!
I have problem with pipe socket.
I need to draw a PVC pipe. To do this, I created a new component. As a prototype component form I chose the pipe with socket, shown in the attached file "pic. 1. SpecEditor". I've made ​​the settings (dimension settings are also visible in the screenshot), added new component to the spec sheet. But when I started to draw this pipe in Plant 3D, I found that newly created pipe has no socket, which I wanted to see. Also, I noticed that the beginning of the pipe body doesn't coincide with the beginning of its axis (see. "Pic. 2. P3D"). After measuring, I found that this difference equals the length of the socket portion. Consequently, the socket portion of the pipe is not displayed for some reason.
I suppose, this is a problem in the OF parameter in SpecEditor, which is responsible for the generation of the wall thickness. For some reason, pipe is always drawn with a wall thickness regardless of the value of OF parameter. I hope, if a drawing of the pipe will be without generating wall thickness, the socket will appear.
Please, help me to find a decision of this problem!
Thanks in advance!
Artyom Khrapov
Refrigeration Systems and Technologies
3 REPLIES 3
KenFauver
in reply to: mcray100500
I suspect you are correct regarding the OF parameter. Try setting OF with a value of -1.
If the post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
Kenneth G. Fauver
Technical Sales Specialist – Plant
Oil and Gas Solutions
mcray100500
in reply to: KenFauver
Thank you Ken! I've tried setting OF with a value of -1. It doesn't work too.Smiley Sad
Artyom Khrapov
I was just dealing with similar issues, so a few years late but I'll give my 2 cents, so anyone else who comes across this post can have a little more guidance.
I found by changing the length to -1, so the software treats it as a "Real Pipe", and setting a fixed length allowed for socket generation.
To still have lengths made 2000 long, set the fixed length to 2000.
Spec Editor (Catalog Side) for Part - Correct Configuration to Allow Socket Port GenerationSpec Editor (Catalog Side) for Part - Correct Configuration to Allow Socket Port Generation
When you add it to spec make sure you tick use fixed length.
Adding the part to the specAdding the part to the spec
Final ProductFinal Product
Lastly I'll note that having connection settings that'll form a joint is important for the routing of the pipe too. So initially when I started double checking for you I had 2x Undefined End Types. By changing them to SO and PL it worked.
As an aside, on the double-port equivalent of the pipe if you wanted to have only one socket you had to generate socket 1, if you didn't generate socket 1 socket 2 wouldn't generate.
I'll further note that I found that OF had no impact on the pipe generation - whether a positive value, 0, or -1
”Boost
