AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
problem with flange connections
6 REPLIES 6
GSC_HAYA
2124 Views, 6 Replies
Hello
since yesterday I can not make flange connections between flanges, flanges and pipe, flanges to nozzles from equipment.
Only from valves I can by using the plus-grip add flanges.
That only occurs when I'm using my own piping class.
I think I had not change anything. I only installed SP2 for Plant3D 2012.
Any ideas?
Guido
Plant3D 2022 German
WIN10 Pro
6 REPLIES 6
Dan.Scales
in reply to: GSC_HAYA
Would you be willing to share a sample project with me so I can try to establish the cause of this issue?
Dan
Dan Scales
GSC_HAYA
in reply to: Dan.Scales
Hi
I think I found the problem. I have british (flanges) and metric parts. When I insert the parts one by one there is no problem. When I use auto-flange this error occurs when I use a flange with british units. The same flange with metric units works....
Do you still need a sample project?
Guido
Plant3D 2022 German
WIN10 Pro
Dan.Scales
You need to enable imperial to metric connections in the Project Setup:
I hope this helps.
Dan
Dan Scales
GSC_HAYA
Hi
it is enabled. The problem occurs only by auto-flange.
Guido
Plant3D 2022 German
WIN10 Pro
MJStander
I have the same problem when trying to insert metric valves into imperial pipe. The imperial to metric connection option is enables but autoflange does not work.
If I manually add a single flange to the end of a pipe, I can add a metric valve, then manualy add a flange then continue routing. Alternatively I can add a flange pair in the center of a section of pipe that has been routed and add the valve between the two flanges.
Does anyone know why autoflange does not work with imperial to metric connections?
K0702297
in reply to: MJStander
Dear all,
  I have a same problem when connect Nozz with flange.
  Please help me.
  Thanks all.
”Boost
