Halo to all,
I have a problem, and I hope that someone have solution or any idea to help me....
I have a pipe header with diameter 30 ", and from that header I must make some number of a small branches.
But problem is: I need to have a weldolet connections (weldolet 30" x 6") to branches.
Axes of Weldolet connection are not in the same axe of header pipe, they are moved a little, not too much, just a 35 mm.
I know that is possible to build on site, but a need to have corrected isometrics...
See picture in attacment
Srdjan
Many Thanks in advanced.
P.S. I have a idea to make a special part, but If is possible to solve with only a pipes, or...I do not know
You would have to make a custom part. Make a zero geometry item, with the offset predefined, and your connect points in the correct locations, and then you can run the continued part from there.
