I want to create a new Valve Report Layout by using Plant report Creator. I have added new Class properties of hand valve in Plant 3D project setup. Those new class properties are now available in Report Designer Field List.
Now I want to add those properties in Hand Valve which are available in Pipe Line Group in Non Engineering Items and Pipe Line Segments in Engineering Items (i,e Service & Pipe Line Tag). In "Edit query" of Report Configuration I have included the available classes of Pipe Line Group & Pipe Line Segment. During Report Print preview the hand Valves are coming twise, one is for Hand valve Class and other is of Pipe Line Group.
Next problem is that I want to add Sl.No. in Report Layout. please help............
Solved by dave.wolfe. Go to Solution.
Hi Bapan,
Can you try adding your SL.NO as a new data source and see whether it helps.
Thank you for your early responce Vinod,
I am trying to Add new DataSource from Report Tasks, its asking "Choose a data Connection/Which connection should th wizard use?". After click on New connection, Data Link Properties dialog box is comming.
How to link data and which data I will connect, please help with detail steps and snap shorts.
may i ask where is your sl.no coming from. These are different databases, if you have those numbers in an excel or access, you could choose one of them. May i ask where these numbers are coming from for your project ?
sl.no is nothing but a Sequential number/serial number, it is not related with project or database.
Hi Bapan,
Just wanted to check with you for an update. Please let us know, if you need further assistance.
We will be glad to assist you further.
Your understanding and support is greatly appreciated. Have a great day !
Vinod.
Hi Vinod...
Acutally Column marked "Sl.No." featuring in the report is not a member of any database or this cell has not been mapped with any Database element and actually it is not possible also ???
As you know we generally provide SL.No. for any table to identify the rows later for reference. Hence we wanted to include this in the report. In my opinion this is possible only when we are able to relate the value of the cell in the previous row. As we do in excel sheet. To create Sl.No. in excel sheet, we just simply add 1 with previous cell value.
I think I could make you understand the matter. expecting early solution from you...
You can use the technique shown here to place a row number.
http://www.pdoteam.com/2012/07/creating-a-bill-of-material-row-number-in-plant-3d-reports/
Thanks Dave, row number is coming properly.
