AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Problem generating isometrics
4 REPLIES 4
493 Views, 4 Replies
HI all
I need that one "tag line" appears in one drawing, if you see my example you can see that it´s only yellow line with the same tag and plant 3D generate 3 drawings...
4 REPLIES 4
mikael
It's really hard to see what you mean in that picture, can you attach a larger picture maybe?
//Mikael
in reply to: mikael
mikael
Have you tried setting the "MaxDirectionChanges" in IsoConfix.xml to 0?
Have a look att the thread pasted below, maybe that will sort your problem as well.
http://forums.autodesk.com/t5/AutoCAD-Plant-3D/Isometric-Sheet-Split/m-p/3695466/highlight/true#M762...
//Mikael
in reply to: mikael
THANKS YOU!!!
I´m very noob at the moment, the solution was "Force Iso onto one sheet" when you generate a iso drawing in the advanced options...
So easy
”Boost
