AutoCAD Plant 3D General DIscussion
Active Contributor
h.eger
Message 1 of 2 (252 Views)
Problem bei Plant 3D 2013 Ortho mit ASD 2013 Datei
252 Views, 1 Replies
11-07-2012 02:25 AM
Guten Morgen Gemeinde,
kann mir dabei jemand helfen?
Es wird zwar alles Dargestellt in P3D aber die ASD Datei läßt sich im Ortho nur bedingt bearbeiten.
Ich bekomme nur ca. 50% von meiner ASD Zeichnung im Ortho aufs Papier.
Meldung in Plant3D 2013:
[RbCSRoot.dbx] Initialization...
[RbCTKernel.dbx] Initialization...
[RbCTKernel.dbx] Initialization done in 0 ms.
[RbCSRoot.dbx] Initialization done in 31 ms.
[RbCSDrawing.DBX] Initialization...
[RbCSDrawing.DBX] Initialization done in 16 ms.
[RbCSMdlObj.dbx] Initialization...
[RbCSMdlObj.dbx] Initialization done in 0 ms.
#\program files\autodesk\autocad plant 3d 2013 - deutsch\asdload.arx kann eine benötigte dll oder andere Datei nicht finden.
Danke und Gruß
Hartmut
Product Support
jason.drew
Message 2 of 2 (122 Views)
Re: Problem bei Plant 3D 2013 Ortho mit ASD 2013 Datei
02-01-2013 09:23 AM in reply to: h.eger
Please try this:
Copy RBCTAppCore.dll file from "c:\Program Files\Autodesk\AutoCAD 2013\ASD" to the ‘main’ folder for Plant 3D which is "c:\Program Files\Autodesk\AutoCAD Plant 3D 2013 - English" (or your localized installation path)
After existing from Plant 3D and launching again, the warning about ASDLoad.arx should no longer show up and will be successfully loaded.
Jason Drew
Premium Support Specialist
Product Support
Autodesk, Inc.
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly.
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
