AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Prinnt 3D-pdf file
4 REPLIES 4
428 Views, 4 Replies
Prinnt 3D-pdf file
I would like to print a 3D pdf file so my clients can view and rotate the the model in adobe.
This feature is default in the Microstation pdf-plotter but I can not find this option in Plant 3D.
Please advice.
4 REPLIES 4
DarrenP
its not there
you would have to rely on 3rd party add ins if available
DarrenP
dgorsman
in reply to: DarrenP
Tetra4D is the only one I know of.  Not sure if it works in verticals like Plant3D, but they do have plug-ins for AutoCAD and Navisworks (a bit of a work-around, but if absolutely necessary...).
Dan.Scales
in reply to: dgorsman
Creating 3D PDF's from Plant 3D is not possible without looking at third party options.
You could try 3DDWF to create a 3D DWF file instead.
Dan
Dan Scales
Create a Navisworks file and get them to install Navisworks Freedom?
Tomislav Golubovic
Technical Specialist - Plant and Infrastructure
Autodesk Australia / New Zealand
Autodesk ANZ YouTube Channel
”Boost
