Hi all,
We have recently upgraded to Plant 3D 2015 and have just used ReCap Pro to stitch our scans together for the first time. The Point Cloud is fine and can be inserted with no problems, however after performing a few commands the Point Cloud is unable to be selected by just clicking on it. I can select it by clicking on the boundary box but we need to be able to select nodes on the Point Cloud.
On occasion the Point Cloud works fine and we can select nodes and crop it as normal, but most of the time Its as if the Point Cloud is just a picture with no intelligence. This is happening on three computers.
Any ideas on how to fix this? I can't even find a way to refresh the Point Cloud to see if that would work?
Thanks.
Solved by kubitTilo. Go to Solution.
Plant 3D Service Pack 2 should do the trick, the following is from the AutoCAD 2015 Service Pack 2 Readme:
