I have been rubbing my head for hours and cant get it work! I have a import a block from a site and convert it as a equipment, then I want to change the scale so thar it fit the pipe size, and then I go to modelling and then 3D scale, So I have my block and then I route a pipe beside whit size 150 for example.
Now I want the block I have download to get the same scale as the pipe so it will fit.
So I start 3D scale and I think I must choose reference length? Then I dont know how to get it worked.
I would be verry grateful if somebody can explain for med how to do, so I get my block at the same scale as the pipe ?
Solved by hussain. Go to Solution.
use 3d scale for the object with following value
scale factor = OD of pipe / OD of hole
Imran
