AutoCAD Plant 3D General DIscussion
Valued Mentor
JohnHolder
Message 1 of 7 (308 Views)
Plotting issue
308 Views, 6 Replies
11-14-2011 12:52 PM
I am using a mix of ORTHO views and the <view> command for a drawing set. the ortho views that I imported into the SSM work fine, all geometry shows up. The views I have from the <view> command and the SSM, some of the piping geometry
does not show up.  all of the piping is on the same layer.  same properties.  just some do not show up.
Also, the views always plot as <3d hidden> regardless of what I set and save them at on the sheet.  As a trial, I changed one sheet to <shaded> and plotted it showed as <3d hidden> then changed to <2d wireframe> and plotted it showing <3d hidden>
I am running out of ideas.
anyone have a suggestion?
John.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Product Support
VinodBalasubramanian
Message 2 of 7 (285 Views)
Re: Plotting issue
11-15-2011 06:43 PM in reply to: JohnHolder
Can you please provide us the drawing and also a screenshot of the plot settings.Please also attach the plot styles, if you are using any.
Vinod Balasubramanian
Valued Mentor
JohnHolder
Message 3 of 7 (274 Views)
Re: Plotting issue
11-16-2011 09:55 AM in reply to: VinodBalasubramanian
what email should I send the drawing to?
Master Yoda.
Valued Mentor
Rich.O.3d
Message 4 of 7 (266 Views)
Re: Plotting issue
11-16-2011 03:36 PM in reply to: JohnHolder
couple of things to check/try/play with
on the properties tab of the viewport you can set 'shade plot'
also top left area of print dialogue box has shade plot drop down
different combos between these can affect the output
although, the views generated using the ortho part of plant arent viewports looking at the model, they are like using solprof...you get what you get, no adjusting display settings, they are a snapshot of a view in the model with hidden edges removed
CAD Management 101:
You can do it your own way,
If its done just how I say!
[Metallica:And Justice For All:1988]
Valued Mentor
JohnHolder
Message 5 of 7 (260 Views)
Re: Plotting issue
11-16-2011 03:54 PM in reply to: Rich.O.3d
ok I can change how it plots and it's working properly again - strage that happened in the first place.
thanks for pointing out the <shade plot> in the properties.
The geometry is still missing in <hidden> <3d hidden>
it shows up with <wireframe> and <shades of grey> etc. during plots
Visually everything is ok in the viewport.
This is the first time I have used ortho views ( new to plant 3d )
I have always used <3d hidden> with views with the sheet set manager with no issues.
it's a bit upsetting that Ortho views and the SSM are not compatable. ( cannot linked ortho views to the sheet view tab )
Still having some of the geometry missing in hidden styles but visible on wireframe and shaded style plots is strange.
Master Yoda.
Product Support
Message 6 of 7 (257 Views)
Re: Plotting issue
11-16-2011 08:26 PM in reply to: JohnHolder
I have sent you a private message with an FTP link to upload the files. Can you please upload it there.
Thank you.
dsmeisle
Message 7 of 7 (132 Views)
Re: Plotting issue
05-04-2012 12:00 PM in reply to: JohnHolder
Was a solution for this issue ever found?  I and (2) other designers here are having the same problem in three different models.
Autodesk Alert | We are currently working on restoring Previous Version License request access in the Autodesk Subscription Center. If you are a subscription customer and would like to request a Previous Version License, please use this link as a temporary workaround. We apologize for the inconvenience and thank you for your patience.
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
