AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Please kindly Help for Isogen Error
2 REPLIES 2
Houto
395 Views, 2 Replies
Dear sir,
I ve founded some error when generating isometric drawing from p3d isogen.
it informed " [Error32] Unknown error in PISOGEN " and point to the path directory that contain drawing and fls file as per attachment
I dont know if this a system or programm error but reinstallation the software can not solve the problem
I ve seach for anwsers in Autodesk site but it can't find way out
Pls kindly help
Many Thanks
WJ Houto
Tags (1)
2 REPLIES 2
ybogdanov
in reply to: Houto
which release do you use?
Probe to generate iso in another project. which is the result?
Yury Bogdanov
ASIDEK(Grupo CT) - Partner Directo de Autodesk
Barcelona (Spain)
PeterQuinn
in reply to: Houto
Two things to try. If isos fail on all drawings, then it might be a path issue. Isogen does not like paths that are too long, contain spaces, or unicode double byte charaters (e.g. chinese, japanese, or korean characters)
If it works on some drawings, then the path isn't an issue. It's most likely a problem with the particular lines themselves. Posting a PCF file might help figure out what's wrong.
Peter Quinn
Senior Product Manager
Autodesk, Inc.
”Boost
