I've encountered a serious issue regarding ORTHO drawings. I am using Plant 3D 2014 version.
I have created a PLANTSTEELMEMBER and PLANTSTELPLATE in my 3D model. After ortho generation I found in my ortho drawing that the PLANTSTEELPLATE dislocated from the original position.
Regards
Bapan Bhandari
Solved by bapan_b. Go to Solution.
Solved by EricNyh. Go to Solution.
I've had something similar happen in the past but I thought this issue had been fixed. Are you running the current sevice packs?
Hi, were you able to resolve this issue?
I'm expericing the same problem since moving computers at work.
Stair stringers are also offset closer to one another by 20mm or so.
Hi
After installing AutoCAD Plant 3D 2014 Service Pack1 in my system, it is working properly.
Download form below link and let me confirm.
Regards Bapan |
