Hello
When I create plant project from existing projects i cant place in vault subfolders only in root - how to?
Regards Lars
I have studied the issue and don't found any Autodesk decision. Only way for you is to move project from root "by hands" or do it by scripts.
It is important for me also!
but does that solution work? it cant get it to work, the paths in project.xml is not changed etc.
I'm not sure and can't to verify for sure now (today I do not have 2014 license).
Generally speaking, it is possible to adjust all settings in vault. Because I need to store Plant 3D not in root, but in custom object, I will plan to create script in Vault like trigger in database, which will be to move project to the location desired for me. Also it is possible to change all the xml files in such script.
It is really sad, that Plant 3D API does not allow to create projects programmatically 😞
