AutoCAD Plant 3D Forum
Welcome to Autodesk’s AutoCAD Plant 3D Forums. Share your knowledge, ask questions, and explore popular AutoCAD Plant 3D topics.
Plantpartconvert AutoCad Plant 2014 port cnt <0>
3 REPLIES 3
info
843 Views, 3 Replies
Dear all,
Port number <0> after plantpartconver command in Plant 2014.
 <?xml version="1.0" encoding="UTF-8"?> -<BlockInfoCollection xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema">
-<blockInfoList>-
<block>
<name>DCV3_DN15</name>
<portCnt>0</portCnt>
<imageName>DCV3_DN15-1346090_1_WEB.dwg_DCV3_DN15.png</imageName></block></blockInfoList></BlockInfoC...>
But no problem in Plant 2013 making the same procedure.
What could be the reason?
3 REPLIES 3
martinTstewart_Adsk
in reply to: info
Sorry for the inconvenience here. This is a known issue that will likely be picked up in the next service pack. See this link for workaround:  http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22088428&linkID=14116967
Martin Stewart
AEC Support Specialist
info
in reply to: martinTstewart_Adsk
Thank you.
This workaround does not work for me. After doing this, I'm able to add to a catalog and then to a spec. But once inserted into the model, there are still no end connections so I can't connect anything to it. I really need to get a fix for this...
”Boost
