AutoCAD Plant 3D General DIscussion
Active Contributor
tarrynd
Message 1 of 7 (337 Views)
PLANTCUSTOMPARTS
337 Views, 6 Replies
08-22-2012 04:09 AM
Hi All
I would like to find out if anybody knows how to reuse a component created using the "PLANTCUSTOMPARTS" command, without copying and pasting it. I also do not want to add this component to my spec I would just like to re use it once or twice in my current project (In different drawings).
*Expert Elite*
dave.wolfe
Message 2 of 7 (333 Views)
Re: PLANTCUSTOMPARTS
08-22-2012 05:58 AM in reply to: tarrynd
Create a drawing that just holds your custom parts. Then when you are asked to select a block, choose select from dwg and browse to your custom parts drawing.  By saving them in an external file, you don't have to worry about cluttering up your models.
Please mark my post as the answer if it answers your question. Marking answers helps other find solutions faster. Thanks!
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Tips and Tricks on our blog: Process Design, from the Outside
A P3D Authorized Reseller
Plant 3d Wish list: https://plant3d.uservoice.com/
Active Contributor
tarrynd
Message 3 of 7 (282 Views)
09-03-2012 02:40 AM in reply to: tarrynd
Hi Dave
Thank you very much, I did try this, but when i navigate to the drawing where the block should be there are no blocks, could this be because when I insert my custon component I use the default blocks and update only the sizes? I dont use my own AutoCAD blocks.
Hope this makes sense.
Tarryn
*Expert Elite*
dave.wolfe
Message 4 of 7 (265 Views)
09-04-2012 07:06 AM in reply to: tarrynd
It i s possible.  Try using the RENAME command to change the name of the blocks.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Active Contributor
tarrynd
Message 5 of 7 (251 Views)
09-05-2012 04:40 AM in reply to: tarrynd
Hi Dave
I tried this, in the rename dialogue box under blocks it is empty, The custom components that I have inserted is in my model area.
When I insert it I am using the following command HOME TAB>Part Insertion>Custom Part
Then i use the Plant 3D shape option and change my values on the right hand side and insert.
Any idea's?
*Expert Elite*
dave.wolfe
Message 6 of 7 (249 Views)
09-05-2012 05:06 AM in reply to: tarrynd
Oh, yea, you can't re-use those.  You'd have to create a catalog item to use those shapes frequently.
Dave Wolfe
Isaiah 57:15
ECAD, Inc.
Active Contributor
tarrynd
Message 7 of 7 (247 Views)
09-05-2012 05:14 AM in reply to: dave.wolfe
It's such a pity, being able to re use custom components inserted in this mannor would have been perfect for what we want. Thanks for you help. And thanks to you guys for your amazing blogs. It's by far the best place to get information on AutoCAD plant 3D.
Tarryn
Announcements
Need installation help?
New AutoCAD Plant 3D Category!
The AutoCAD Plant 3D forum has moved into it's very own category page, and can no longer be found within the Additional Product Forums.
