plant 3D objects do not work with viewbase, why not?
also piping objects do not plot correctly, missing line elements on all pipe & many fittings
No External References....
No View!
R.
Hartmut
Hartmut Eger
Senior Engineer
Anlagenplanung + Elektotechnik
XING | LinkedIn
You are likely going to have to explode the plant objects down to raw 3d solids to get the lines to show/hide correctly. Pipe needs to be exploded once while most fittings will need to be exploded twice.
VIewbase only works with solids. You can probably explode the Plant 3D objects to solids or do as ExporttoAutoCAD and then run viewbase.
