Good afternoon,
I tried to export some line numbers to an excel sheet to change the line number, but when I import it and try to accept the changes it says that it's not possible because is in use by another object.
Is any easy way to export the line numbers, modify on an excel and then import it again?
Similar problem. When I try to import it shows a message saying that the line tag number is not unique...
But it shouldn't be, as I am giving the same line number to the pipes that have the same properties (length and olets position).
Any answer??
I need to do it via Excel, otherwise I would spend hours selecting pipes to give them number tags
Hi @davidsuarez82, @johnladec,
When you make the edits in the Excel are you changing the Tag or the LineNumber property that is part of the tag?
If it is the Tag, then try editing the LineNumber property instead.
Dan
